Code as follows :
Master:
#include <Wire.h>
Wire.pins(5,4);
Wire.begin(8); // join i2c bus with address #8
Wire.onReceive(receiveEvent); // register event
Serial.begin(115200); // start serial for output
delay(100);
// function that executes whenever data is received from master
// this function is registered as an event, see setup()
void receiveEvent(int howMany) {
Serial.println("Received..");
while (1 < Wire.available()) { // loop through all but the last
char c = Wire.read(); // receive byte as a character
Serial.print(c); // print the character
int x = Wire.read(); // receive byte as an integer
Serial.println(x); // print the integer
Slave:
#include <Wire.h>
Wire.pins(5,4);
delay(100);
Help from anyone who has pulled this off would be great.
