By Skynet_AI
#63621 Hi
I'm new to this all, I was finally able to install the package. I choice board NodeMCU 1,0 since that is what I have. I tried to compile the blink program and I get this error can some help me solve the problem? Thanks Son
Error message output from IDE
Arduino: 1.8.1 (Windows XP), Board: "NodeMCU 1.0 (ESP-12E Module), 80 MHz, 115200, 4M (3M SPIFFS)"
C:\Program Files\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Administrator\My Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10801 -build-path C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\untitled1055512808.tmp\sketch_mar12a\sketch_mar12a.ino
C:\Program Files\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files\Arduino\hardware -hardware C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages -tools C:\Program Files\Arduino\tools-builder -tools C:\Program Files\Arduino\hardware\tools\avr -tools C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages -built-in-libraries C:\Program Files\Arduino\libraries -libraries C:\Documents and Settings\Administrator\My Documents\Arduino\libraries -fqbn=esp8266:esp8266:nodemcuv2:CpuFrequency=80,UploadSpeed=115200,FlashSize=4M3M -ide-version=10801 -build-path C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523 -warnings=none -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2 -prefs=runtime.tools.mkspiffs.path=C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\mkspiffs\0.1.2 -prefs=runtime.tools.esptool.path=C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\esptool\0.4.9 -verbose C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\untitled1055512808.tmp\sketch_mar12a\sketch_mar12a.ino
Using board 'nodemcuv2' from platform in folder: C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Using core 'esp8266' from platform in folder: C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0
Detecting libraries used...
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\sketch\sketch_mar12a.ino.cpp" -o "nul"
Generating function prototypes...
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -ffunction-sections -fdata-sections -w -x c++ -E -CC -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\sketch\sketch_mar12a.ino.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\preproc\ctags_target_for_gcc_minus_e.cpp"
"C:\Program Files\Arduino\tools-builder\ctags\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\preproc\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\sketch\sketch_mar12a.ino.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\sketch\sketch_mar12a.ino.cpp.o"
Compiling libraries...
Compiling core...
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -g -x assembler-with-cpp -MMD -mlongcalls -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\cont.S" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\cont.S.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\cont_util.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\cont_util.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_eboot_command.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_eboot_command.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_flash_utils.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_flash_utils.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_i2s.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_i2s.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_noniso.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_noniso.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_phy.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_phy.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_postmortem.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_postmortem.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_si2c.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_si2c.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_timer.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_timer.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_wiring.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_wiring.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_wiring_analog.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_wiring_analog.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_wiring_digital.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_wiring_digital.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_wiring_pulse.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_wiring_pulse.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_wiring_pwm.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_wiring_pwm.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\core_esp8266_wiring_shift.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\core_esp8266_wiring_shift.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\heap.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\heap.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\libc_replacements.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\libc_replacements.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\time.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\time.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\uart.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\uart.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\libb64\cdecode.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\libb64\cdecode.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\libb64\cencode.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\libb64\cencode.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs\spiffs_cache.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\spiffs\spiffs_cache.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs\spiffs_check.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\spiffs\spiffs_check.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs\spiffs_gc.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\spiffs\spiffs_gc.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs\spiffs_hydrogen.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\spiffs\spiffs_hydrogen.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\spiffs\spiffs_nucleus.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\spiffs\spiffs_nucleus.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-gcc" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -Wpointer-arith -Wno-implicit-function-declaration -Wl,-EL -fno-inline-functions -nostdlib -mlongcalls -mtext-section-literals -falign-functions=4 -MMD -std=gnu99 -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\umm_malloc\umm_malloc.c" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\umm_malloc\umm_malloc.c.o"
"C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2/bin/xtensa-lx106-elf-g++" -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/include" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0/tools/sdk/lwip/include" "-IC:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523/core" -c -w -Os -g -mlongcalls -mtext-section-literals -fno-exceptions -fno-rtti -falign-functions=4 -std=c++11 -MMD -ffunction-sections -fdata-sections -DF_CPU=80000000L -DLWIP_OPEN_SRC -DARDUINO=10801 -DARDUINO_ESP8266_NODEMCU -DARDUINO_ARCH_ESP8266 -DARDUINO_BOARD="ESP8266_NODEMCU" -DESP8266 "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266" "-IC:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\variants\nodemcu" "C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\Esp.cpp" -o "C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\arduino_build_783523\core\Esp.cpp.o"
In file included from c:\documents and settings\administrator\local settings\application data\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\memory:62:0,
from C:\Documents and Settings\Administrator\Local Settings\Application Data\Arduino15\packages\esp8266\hardware\esp8266\2.3.0\cores\esp8266\Esp.cpp:24:
c:\documents and settings\administrator\local settings\application data\arduino15\packages\esp8266\tools\xtensa-lx106-elf-gcc\1.20.0-26-gb404fb9-2\xtensa-lx106-elf\include\c++\4.8.2\bits\stl_algobase.h:59:28: fatal error: bits/c++config.h: No such file or directory
#include <bits/c++config.h>
compilation terminated.
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module).
By martinayotte
#63681 This issue is well described in several bugs reported : it is related to Windows long path with spaces.
https://github.com/esp8266/Arduino/issues/2387
https://github.com/esp8266/Arduino/issues/2250
https://github.com/esp8266/Arduino/issues/1631
