By Diogo Martins
#64453 Hello people!
I'm studying about this module for a while but i've not found a similar application to the one I want to do.
I want to use a MCU, not Arduino, to receive some data and send through ESP8266 via WIFI to another ESP8266 via WIFI.
Both boards will have a MCU and an ESP8266.
My question is, how do I do this without having to program a custom firmware to ESP8266? I want to use it as it comes.
What's the peripheral(I2C, UART, SPI) that I may use for it?
Thanks.
By urbanze
#64555 sending data with 2 or more ESP? do with wireless (or no), use server and client library to simple send data, see this example:
esp1 connect and send data to esp2 server.
Sending data:
WiFiClient cl;
void setup()
   pinMode(LED_BUILTIN, OUTPUT);
   WiFi.mode(WIFI_STA);
   reconnect();
void loop()
   while (WiFi.status() == WL_CONNECTED)
      cl.println("1");//Sending "1" to another esp8266
      digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
      delay(2000);
   reconnect();
void reconnect()
   WiFi.disconnect();
      WiFi.begin("xxxxxx", "xxxxxx");
      delay(5000);
   cl.connect("192.168.4.1", 23);
Receiving data:
WiFiServer sv(23);
WiFiClient cl;
void setup()
   WiFi.mode(WIFI_AP);
   WiFi.softAP("xxxxx", "xxxxx");
   sv.begin();
   delay(25);
void loop()
   while (cl.connected())
      String req = cl.readStringUntil('\r');
      if (req == "1")
         //do anything
      if (req == "2")
         //do anything
      if (req == "3")
         //do anything
      if (req == "4")
         //do anything
   recreate();
void recreate()
   while (sv.hasClient() == 0)
      delay(50);
   digitalWrite(LED_BUILTIN, 1);
   cl = sv.available();
