By lorin
#64760 Hi all,
Few days ago I bought some ESP modules and started playing with them. I am able to upload a sketch, however I got no response to Serial Monitor. I would expect IP address to connect to and some additional data:
Code: Select all/*
 *  This sketch demonstrates how to set up a simple HTTP-like server.
 *  The server will set a GPIO pin depending on the request
 *    http://server_ip/gpio/0 will set the GPIO2 low,
 *    http://server_ip/gpio/1 will set the GPIO2 high
 *  server_ip is the IP address of the ESP8266 module, will be
 *  printed to Serial when the module is connected.
const char* ssid = "Popelarka";
const char* password = "rony1997";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
  //Serial.setDebugOutput(true);
  delay(10);
  // prepare GPIO2
  pinMode(5, OUTPUT);
  digitalWrite(5, 0);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  Serial.println(req);
  client.flush();
  // Match the request
  int val;
  if (req.indexOf("/gpio/0") != -1)
    val = 0;
  else if (req.indexOf("/gpio/1") != -1)
    val = 1;
  else {
    Serial.println("invalid request");
    val = 0;
    //client.stop();
  // Set GPIO2 according to the request
  digitalWrite(5, val);
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nGPIO is now ";
  s += (val)?"high":"low";
  s += "</html>\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
The code is barely edited example shipped with ESP arduino library.
I use this wiring for programming:
Code: Select allESP <-> USB2Serial
TX   ->    RX
RX   ->   TX
D0   ->   GND
D2   ->   VCC
D15   ->   GND
GND   ->   GND
Reset   ->   Reset
CH_PD   ->   VCC
VCC   ->   +5V
I selected Generic ESP8266 board in Arduino IDE and left all settings without changes.
Programmer: https://www.arduino.cc/en/Main/USBSerial
ESP module: http://www.ebay.com/itm/191981905297?ul_noapp=true
I suppose it is worth to point out, that all pins are soldered by myself - this could lead to some unexpected behavior (I am not good at soldering at all) too.
Could you please give me any suggestions what I am doing wrong?
