- Sun Apr 23, 2017 10:39 am
#65168
Hi
As I am new to ESP8266Basic, the code supplied by you was of great help. I want to use the module to control the terrarium of my daughter's bearded dragon. It has a few lights for UV, infra red and heating. I must also measure the temperature and humidity. As said I used your code and the basic routine work perfect. I am only finished with the manual switching and display, I must still do the automation where the lights can be controlled at a certain time and temperature. I did encounter something strange, where I do not know if it is my own stupidity or a bug. The program also display the current time and date in a cell of the table with the time() command and it is updated every second which shows then as a normal clock. The data (date and time) however is cut of at the end and does not show the full date and time in the cell. For example the last part of 2017 only shows 20 in Firefox on Microsoft OS and 201 in IE on Microsoft OS. The strange part of is on my Android tablet and cellular phone it shows correctly as 2017 in the browser. I was always under the impression that the cell width should adjust automatically to the length of data that is presented in the cell. Do you have any ideas maybe?
My code is as follows :
PinDHT = 12
DHT.SETUP(11 , PinDHT)
Lig1 = "Af"
Lig2 = "Af"
Lig3 = "Af"
cls
timer 1000, [branch] ' ## Time for auto refresh variables ##
gosub [readdata]
wprint |<body style="background-color:powderblue;">|
wprint |<H1><span style="color: red;">|
wprint "I/O Controller with Date, Time, Temperature and Humidity Display"
wprint "</H1>"
wprint "</span>"
wprint "<table border='1'><tr><td>Datum</td><td>"
textbox Dagentyd
wprint "</td></tr><tr><td>Humidity </td><td>"
textbox Hum
wprint "</td></tr><tr><td>Temperature Deg C</td><td>"
textbox Temp
wprint "</td></tr><tr><td>Lig 1</td><td>"
textbox Lig1
wprint "</td></tr><tr><td>Lig 2</td><td>"
textbox Lig2
wprint "</td></tr><tr><td>Lig 3</td><td>"
textbox Lig3
wprint "</td></tr></table><p>"
wprint "<p> Click to switch red led <br>"
button "On",[onred]
button "Off",[offred]
wprint "<p> Click to switch green led <br>"
button "On",[ongreen]
button "Off",[offgreen]
wprint "<p> Click to switch yellow led <br>"
button "On",[onyellow]
button "Off",[offyellow]
wprint "<p> Click to Exit <br>"
button "Exit", [TestExit]
Wait
[onred]
io(po,14,1)
Lig1 = "Aan"
Wait
[offred]
io(po,14,0)
Lig1="Af"
Wait
[ongreen]
io(po,4,1)
Lig2 = "Aan"
Wait
[offgreen]
io(po,4,0)
Lig2 = "Af"
Wait
[onyellow]
io(po,5,1)
Lig3 = "Aan"
Wait
[offyellow]
io(po,5,0)
Lig3 = "Af"
wait
[TestExit]
timer 0
end
[branch]
gosub [readdata]
wait
[readdata]
Dagentyd = time() 'Current Date and Time
Temp = DHT.TEMP() 'Current Temperature
Hum = DHT.HUM() 'Current Humidity
return
