davydnorris wrote:I'm still trying to get a way to runCode: Select allin headless mode so that we can automate it from a Makefile.ct_ng menuconfig
BTW, there's https://git.kernel.org/pub/scm/linux/ke ... _config.sh
Explore... Chat... Share...
jcmvbkbc wrote:davydnorris wrote:- sysroot based toolchains for 'bare metal' (ie. Non-OS based) systems were removed in 1.22 because there was unnecessary and incorrect duplication of include and lib structures.
I'm not sure about that, but I didn't have enough time for a good look at it. My current impression is that it complicates the setup (supporting two configurations: sysrooted and non-sysrooted instead of one) and makes it less flexible (one cannot pass --sysroot option to the components of non-sysrooted toolchain).
jcmvbkbc wrote:davydnorris wrote:I'm still trying to get a way to runCode: Select allin headless mode so that we can automate it from a Makefile.ct_ng menuconfig
