By Einhornkot
#66157 Hi,
I use a Node to control my 433mhz sockets, which are placed in my garden, with a small webpage.
I use a PowerLine-adaptor to bring Wifi to my garden.
Now I put my Node in the summerhouse next to the adaptor.
If I plug the Node in, I can access for about 60sec to the webpage, then I can´t.
I think that the problem is that the Powerline-adaptor loses every ~60sec for about 1sec the connection to the other adaptor at my router.
How can I reconnect the Node to the Wifi-Network?
Philipp
Here is my code:
const char* ssid = "WLAN7618";
const char* password = "xxxxxxxxxx";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
#include <RCSwitch.h>
RCSwitch mySwitch = RCSwitch();
  delay(1);
  mySwitch.enableTransmit(2);
  mySwitch.setPulseLength(180);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(1);
  Serial.println(req);
  client.flush();
  y\">Reiherschreck Off</a></li></ul><p></body>";
  s += "</html>\n";
  // Send the response to the client
  client.print(s);
  delay(1);
  Serial.println("Client disconnected");
  // The client will actually be disconnected
  // when the function returns and 'client' object is detroyed
