I flashed the code into three modules and powered them on. A Mesh was created. It seem to work well. I noticed that if you change the baud rate of a module then power it off and back on the baud rate change is not persistant and gets reset back to 115200. This is unfortunate for me because I only have two FTDI modules capable of 115200. So I could only monitor two of the three ESP modules. I have a slew of old serial modules that will run 9600 but since the ESP boots at 115200 I can't use these old modules unless the baud rate change can be made persistant.
Anyway, The three ESP modules worked as a mesh. It looks like one of the modules was sending data to only one link. In this case link 251. I was able to squeeze the AT+CIFSR, AT+CWLIF and AT+CIPSTATUS commands into the mix and sure 'nough CIPSTATUS showed one connection of 251. See Excerpt data capture:
AT+CIFSR
+CIFSR:APIP,"38.64.158.0"
+CIFSR:APMAC,"1a:fe:34:9e:40:26"
+CIFSR:STAIP,"130.62.158.100"
+CIFSR:STAMAC,"18:fe:34:9e:40:26"
OK
AT+CWLIF
-> SEND OK
AT+CIPSTATUS
STATUS:2
+CIPSTATUS:251,"TCP","130.62.158.0",9999,0
OK
***********Network Links ***************
Link no, Total link : [Source_ID > Dest_ID]
0,3 : [1117 > 9607]
1,3 : [9607 > 91845]
2,3 : [91845 > 1117]
************************ END **************
>>> AP Good. State= 9
-> SEND OK
0,3 : [1117 > 9607]
+IPD,251,38B:>$:9607 ,91845:91845,1117 :1117 ,9607
OK
0,3 : [1117 > 9607]
>>> AP Good. State= 9
-> SEND OK
0,3 : [1117 > 9607]
OK
0,3 : [1117 > 9607]
>>> AP Good. State= 9
-> SEND OK
0,3 : [1117 > 9607]
OK
Things rocked along then all of a sudden a fourth radio showed in the mesh. Somehow mesh node 91845 got a 6 appended and added to the mesh as 918456.
0,3 : [1117 > 9607]
>>> AP Good. State= 9
-> SEND OK
0,3 : [1117 > 9607]
OK
0,3 : [1117 > 9607]
>>> AP Good. State= 9
-> SEND OK
> 3 : [918456,918456,1117]
0,4 : [1117 > 9607]
1,4 : [9607 > 91845]
2,4 : [91845 > 1117]
3,4 : [918456 > 1117]
OK
+IPD,251,50B:STAIP-"131.0.158.100"
STAMC-"18:fe:34:9e:3e:82"
OK
0,4 : [1117 > 9607]
>>> AP Good. State= 9
-> SEND OK
0,4 : [1117 > 9607]
OK
AT+CIFSR
OK
AT+CWLIF
-> SEND OK
AT+CIPSTATUS
STATUS:2
OK
The other module I could monitor showed three links via the AT+CIPSTATUS command and data being sent to all three links. Once again I squeezed a CIPSTATUS command in.:
>>> AP Good. State= 9
-> SEND OK
AT+CIFSR
+CIFSR:APIP,"130.62.158.0"
+CIFSR:APMAC,"1a:fe:34:9e:3e:82"
+CIFSR:STAIP,"38.64.158.100"
+CIFSR:STAMAC,"18:fe:34:9e:3e:82"
OK
AT+CWLIF
SEND OK : CLIENT
AT+CIPSTATUS
STATUS:2
+CIPSTATUS:0,"TCP","130.62.158.100",39193,1
+CIPSTATUS:1,"TCP","130.62.158.101",1389,1
+CIPSTATUS:251,"TCP","38.64.158.0",9999,0
0,3 : [9607 > 91845]
1,3 : [91845 > 1117]
2,3 : [1117 > 9607]
+IPD,251,51B:>$:1117 ,9607 :9607 ,1117 :91845,1117 :918456,1117
OK
2,3 : [1117 > 9607]
+IPD,0,51:>$:1117 ,9607 :9607 ,1117 :91845,1117 :918456,1117
OK
SEND OK : CLIENT
2,3 : [1117 > 9607]
+IPD,1,38:>$:91845,9607 :9607 ,91845:1117 ,9607
OK
SEND OK : CLIENT
2,3 : [1117 > 9607]
>>> AP Good. State= 9
-> SEND OK
2,3 : [1117 > 9607]
OK
2,3 : [1117 > 9607]
OK
I reset one of the nodes then noticed messages going to links 4 and 5 rather than 0 and 1 as I had seen on initialization. CIPSTATUS gave an interesting result.
2,3 : [1117 > 9607]
>>> AP Good. State= 9
-> SEND OK
2,3 : [1117 > 9607]
+IPD,251,38B:>$:91845,9607 :9607 ,91845:1117 ,9607
OK
AT+CIFSR
+CIFSR:STAIP,"131.0.158.100"
OK
AT+CWLIF
-> SEND OK
AT+CIPSTATUS
STATUS:2
+CIPSTATUS:2,"TCP","130.62.158.100",45239,1
+CIPSTATUS:3,"TCP","130.62.158.100",18138,1
+CIPSTATUS:4,"TCP","130.62.158.100",49332,1
+CIPSTATUS:5,"TCP","130.62.158.100",10440,1
+CIPSTATUS:251,"TCP","131.0.158.0",9999,0
OK
2,3 : [1117 > 9607]
+IPD,5,38:>$:1117 ,9607 :9607 ,91845:91845,1117
OK
SEND OK : CLIENT
2,3 : [1117 > 9607]
+IPD,4,38:>$:91845,9607 :9607 ,91845:1117 ,9607
OK
SEND OK : CLIENT
2,3 : [1117 > 9607]
>>> AP Good. State= 9
-> SEND OK
2,3 : [1117 > 9607]
OK
2,3 : [1117 > 9607]
OK
SEND OK : CLIENT
2,3 : [1117 > 9607]
OK
SEND OK : CLIENT
I was able to AT+Close links 0,1,2 and 3. After some period of time the messages migrated from going to links 4 and 5 back to 0 and 1. I then closed links 4 and 5.
Like I said, this is really cool stuff you're doing. I'll be glad to continue to help test future releases if you'd like. I have 6 ESP-01 modules I can use for testing but would be glad to get more if it'ld help.
Keep up the good work!
BB
