As the title says... Chat on...
By faramon
#64703 Hi,
I have mqtt on my NodeMcu with Esp8266 v0.9 and apropriate firmware.
Mqtt works great.
but I found problem with Mqtt when wifi or internet is down and when reconnect, mqtt is not able to reconnects to works like usual. It doesn't receive or publish payloads and I get message that it is offline.
How to resolve the problem with Mqtt and wifi reconnection?
Thanx,
Faramon
By faramon
#64730 After 15 hours of work on this problem, I think I solve the problem.
My NodeMcu have 4 scripts in Lua that makes my aplication for wifi connection stable.
First is init.lua (for now I have test.lua):
Code: Select allprint("ESP8266 module start")
app = require("application")
config = require("config")
setup = require("setup")
setup.start()
second is config.lua:
Code: Select alllocal module = {}
module.SSID = {}
module.SSID["mySSID"] = "myWifiPass"
module.BROKER = "m20.cloudmqtt.com"
module.UN = 'myUsername'
module.PS = 'myPassword'
module.RECONNECT = 0
module.QOS = 0
module.PORT = 12986
module.KEEPALIVE = 120
module.ID = node.chipid()
module.SUBPOINT = "temp/status"
module.PUBPOINT = "temp/messages"
module.RETAIN = 0
module.GETTIME = "test/gettime"
module.PRINTTIME = "test/printtime"
return module
then setup.lua:
local function wifi_wait_ip()
  if wifi.sta.getip()== nil then
    print("IP unavailable, Waiting...")
  else
    tmr.stop(1)
    print("\n====================================")
    print("ESP8266 mode is: " .. wifi.getmode())
    print("MAC address is: " .. wifi.ap.getmac())
    print("IP is "..wifi.sta.getip())
    print("====================================")
    app.start()
  end
end
local function wifi_start(list_aps)
    if list_aps then
        for key,value in pairs(list_aps) do
            if config.SSID and config.SSID[key] then
                wifi.setmode(wifi.STATION);
                wifi.sta.config(key,config.SSID[key])
                wifi.sta.connect()
                print("Connecting to " .. key .. " ...")
                --config.SSID = nil  -- can save memory
                tmr.alarm(1, 2500, 1, wifi_wait_ip)
            print("Connected!")
            end
        end
    else
        print("Error getting AP list")
    end
end
function module.start()
  print("Configuring Wifi ...")
  wifi.sta.getap(wifi_start)
end
return module
and final is application.lua:
m = nil
-- Toggling LED or Relay - signal OUT
local pin = 4  --> GPIO2
local value = gpio.LOW
gpio.mode(pin, gpio.OUTPUT)
gpio.write(pin, value)
local function pingTime()
    m:publish(config.GETTIME, "gettime", config.QOS, config.RETAIN, function(conn)
    end)
end
local function toggleLed (pPin, pValue)
    gpio.write(pPin, pValue)
end
-- Sends my id to the broker for registration
local function register_myself()
    print("Subscribing...")
    m:subscribe({[config.SUBPOINT]=config.QOS, [config.PRINTTIME]=config.QOS, nil})
end
local function mqtt_start()
   -- Connect to broker
    m:connect(config.BROKER, config.PORT, config.QOS, config.RECONNECT, function(con)
      print("Connected!")
        register_myself()
        pingTime()
    end,
    function(client, reason)
        print("failed reason: " .. reason)
    end)
    -- on receive message
    m:on("message", function(conn, topic, data)
        print(topic .. ":" )
        if data ~= nil then
          print(data)
          -- do something, we have received a message
          if data == "1" then
            print("On")
            toggleLed(pin, gpio.HIGH)
          end
          if data == "0" then
            print("Off")
            toggleLed(pin, gpio.LOW)
          end
        end
    end)
   -- This is part when wifi disconnects and I tested it for 5 minutes connecting wifi back and this works
    m:on("offline", function(client)
      print ("Offline " .. config.ID)
      --print(node.heap())
      tmr.start(1)
    end)
    print("Connecting to broker...")
end
--------------------- Wifi part again ----------------------------------
  else
    tmr.stop(1)
    --app.start()
    return true
  end
end
    if list_aps then
                wifi.sta.connect()
                tmr.alarm(1, 5000, 1, wifi_wait_ip)
                print("Connected!")
            end
        end
    else
    end
end
  print("Starting MQTT module...")
  -- initiate the mqtt client and set keepalive timer to 120sec
  m = mqtt.Client(config.ID, config.KEEPALIVE,  config.UN, config.PS)
  m:lwt("temp/messages", "Offline " .. config.ID, 0, 0)
  mqtt_start()
end
return module
If you find bugs or inappropriate behavior, please let me know!
Thanx,
Faramon
