I'd like to eliminate the millis() and use Ticker.
I am at the learning-experiment phase here.
Suggestions?
// Adafruit IO Publish Example, modified to do other stuff too
#include "config.h"
#include <DHT.h>
#define DHTPIN D4 //pin gpio 2 in sensor
#define LED_PIN D5
#define LED_TOGGLE D3
#define BUTTON_PIN D6
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE);
unsigned long previousMillis = 0;
unsigned long currentMillis;
const long interval = 30000;
bool ToggleState = false;
float humid = 0.0;
float temp_C = 0.0;
float temp_F = 0.0;
int good_temp;
int errorcount = 0;
// Functions
int gettemp();
// set up the feeds
AdafruitIO_Feed *humidity = io.feed("humidity");
AdafruitIO_Feed *temperatureC = io.feed("temp_C");
AdafruitIO_Feed *temperatureF = io.feed("temp_F");
AdafruitIO_Feed *LEDState = io.feed("ToggleState");
AdafruitIO_Feed *digital = io.feed("digital");
dht.begin();
pinMode(BUTTON_PIN, INPUT_PULLUP);
pinMode(LED_PIN, OUTPUT);
pinMode(LED_TOGGLE, OUTPUT);
digitalWrite(LED_PIN, HIGH);
digitalWrite(LED_TOGGLE, HIGH);
// start the serial connection
// wait for serial monitor to open
while(! Serial);
Serial.print("Connecting to Adafruit IO");
// connect to io.adafruit.com
io.connect();
// wait for a connection
while(io.status() < AIO_CONNECTED) {
// we are connected
Serial.println(io.statusText());
digital->onMessage(handleMessage);
errorcount = 0;
// io.run(); is required for all sketches.
// it should always be present at the top of your loop
// function. it keeps the client connected to
// io.adafruit.com, and processes any incoming data.
io.run();
currentMillis = millis();
if(currentMillis - previousMillis > interval) {
previousMillis = currentMillis;
digitalWrite(LED_PIN, LOW);
while( good_temp = gettemp() ){
Serial.println( errorcount++ );
delay(100);
ToggleState = digitalRead(D3);
int gettemp(){
// Grab the current state of the sensor
humid = (int)dht.readHumidity();
temp_C = (int)dht.readTemperature();
temp_F = (int)dht.readTemperature(true);
if( temp_C < 200 || humid < 150 ){ // filter out the integer-cast NANs
// Publish data
if (! temperatureC->save(temp_C))
Serial.println(F("Failed to publish temperature"));
else
Serial.print(F("Temperature published: "));
Serial.print(temp_C);
Serial.println(F("C"));
if (! temperatureF->save(temp_F))
else
Serial.print(temp_F);
Serial.println(F("F"));
if (! humidity->save(humid))
Serial.println(F("Failed to publish humidity"));
else
Serial.print(F("Humidity published:"));
Serial.println(humid);
return 0;
}else{
Serial.println(F("invalid data received from sensor"));
return 1;
void handleMessage(AdafruitIO_Data *data) {
Serial.print("received <- ");
Serial.println(data->value());
if(data->toPinLevel() == HIGH){
digitalWrite(LED_TOGGLE, LOW);
Serial.println("HIGH");
}else{
Serial.println("LOW");
