QuickFix wrote:
- Always and only supply a stable 3.3V (at least around 500mA) to the ESP (and any of its pins)
- If you need to connect pins to 5V logic, use a level-shifter
- Never pull an ESP-port up to 5V, only pull up to 3.3V
- Did I already say that the ESP only accepts a stable 3.3V power supply of at least 500mA?
Right, so when using a voltage regulator on the mounting board the issue is I don't have a 3.3v rail to connect to. I guess that's an issue with using this type of regulator that is mounted. I guess my question was about how people who use the mounted regulator solve this problem.
