I activated the debug on Serial port, and I get some debug info which I don't know the meaning.
i.e. wifi evt: 7, where do I find the debug file/error with some specs?
Thanks
Explore... Chat... Share...
* callback for WiFi events
* @param arg
void ESP8266WiFiGenericClass::_eventCallback(void* arg) {
System_Event_t* event = reinterpret_cast<System_Event_t*>(arg);
DEBUG_WIFI("wifi evt: %d\n", event->event);
if(event->event == EVENT_STAMODE_DISCONNECTED) {
DEBUG_WIFI("STA disconnect: %d\n", event->event_info.disconnected.reason);
WiFiClient::stopAll();
for(uint32_t i = 0; i < cbEventList.size(); i++) {
WiFiEventCbList_t entry = cbEventList[i];
if(entry.cb) {
if(entry.event == (WiFiEvent_t) event->event || entry.event == WIFI_EVENT_MAX) {
entry.cb((WiFiEvent_t) event->event);
typedef enum {
WIFI_EVENT_STAMODE_CONNECTED = 0,
WIFI_EVENT_STAMODE_DISCONNECTED,
WIFI_EVENT_STAMODE_AUTHMODE_CHANGE,
WIFI_EVENT_STAMODE_GOT_IP,
WIFI_EVENT_STAMODE_DHCP_TIMEOUT,
WIFI_EVENT_SOFTAPMODE_STACONNECTED,
WIFI_EVENT_SOFTAPMODE_STADISCONNECTED,
WIFI_EVENT_SOFTAPMODE_PROBEREQRECVED,
WIFI_EVENT_MAX
} WiFiEvent_t;
