I ask the help of my friends for a problem I'm having.
This is an application with NodeMcuonde where it is the client and will connect on a server (C # PC application).
It happens that I have to tell the IP of the server to which the client will connect, and this is placed in the code before void setup ().
Here comes the problem because I will read the eeprom to get the IP address stored there (it can be changed) I get the IP but the IPAdress does not update with the IP value and the module does not connect to the server.
String ipA = "";
String ipB = "";
String ipC = "";
String ipD = "";
byte b = ipA.toInt();
byte c = ipB.toInt();
byte d = ipC.toInt();
byte e = ipD.toInt();
byte ip[] = {};
IPAddress Servidor(ip);
char* rede_wifi = "rodrigo_cirilo";
char* senha = "rc40507090";
WiFiClient Cliente;
void setup()
Serial. begin(9600);
EEPROM.begin(512);
for (int i = 64; i < 67; ++i)
ipA += char(EEPROM.read(i));
Serial.print(ipA);
for (int i = 67; i < 70; ++i)
ipB += char(EEPROM.read(i));
Serial.print(ipB);
for (int i = 70; i < 73; ++i)
ipC += char(EEPROM.read(i));
Serial.print(ipC);
for (int i = 73; i < 76; ++i)
ipD += char(EEPROM.read(i));
Serial.print(ipD);
byte ip[] = { b, c, d, e };
IPAddress Servidor(ip); /// //// If I put it here it does not update with the correct value
aqui a função para buscar pelo servidor
void ClientRequest()
// First Make Sure You Got Disconnected
// Cliente.stop();
if(Cliente.connect(Servidor, PORTA))
Cliente.print (MAC); // endereço
chave = true;
chave1 = true;
