hdrut wrote:KevS_OC wrote:I've been trying to get this to work on an esp8266-12e. I've tried as best I can to follow your wiring diagram, but it appears that either the lines are drawn over each other, or there are a lot of common connections. Have you tried this with the 12e to slim down the amount of wiring with switches, etc? Thanks!
Hi,
there are actually some GPIOs which are shared and must be switched after boot up, as the diagram suggests. This was a proof of concept and as such my intention was to just see if ESP8266 could read data coming from the camera and at what rate. Otherwise this module is evidently not fast enough to handle any video rate. Please tell me if I can help you in any way.
Greetings.
P.S. I sent you a LinkedIn request if you are still active there. Thanks again!
