FB_IoT-MqttServer File is actually the ESPMqTT module
ESP8266true_random
RTC
rbase64
I resolved the dependencies above ..it now compiles.....I do a bit of testing
Explore... Chat... Share...
picstart wrote:Instructions say
About note 1: I make a change to MqTT client library to support persistent messages :
I inserted line 148 with ” v = v & 0xFD ”
Issue
I am having trouble locating this file MqTT client ......being explicit with name plus extension never hurts
