Thanks for any help.
Explore... Chat... Share...
#include <SPI.h>
#include <WiFi.h>
IPAddress ip(192, 168, 0, 31);
char ssid[] = "woodssid";
char pass[] = "43fcepass";
int status = WL_IDLE_STATUS;
void setup()
Serial.begin(9600);
while (!Serial) {
WiFi.config(ip);
while ( status != WL_CONNECTED) {
Serial.print("Attempting to connect to SSID: "); <<< I never see this line
Serial.println(ssid);
status = WiFi.begin(ssid, pass);
// wait 10 seconds for connection:
delay(10000);
// print your WiFi shield's IP address:
Serial.print("IP Address: ");
void loop () {}
