There is also an example that provides humidity in %, and temperature in Farenheit and Celsius.
I've put Pigs FLy in the credits, please watch it and tell me if you agree. Maybe you prefer a real name.
Explore... Chat... Share...
alko wrote:Highest bit of temperature is '1' it means that temperature is below '0'.Code: Select allif bit.isset(temperature, 15) then
temperature = -bit.clear(temperature , 15)
end
