martinayotte wrote:The example above is pretty straight forward.
Instead of doing WiFi.begin() and WiFi.status(), simply do the following as in the example :Code: Select allWiFi.softAP(ssid, password);
Serial.println(myIP);
Thank you again,
Now I have following, but there doesn't seem to appear an SSID with the name "MySSID" to be around:
#include <DHT.h>
#include <DHT_U.h>
#include "espipswitchtoggle.h"
const char* ssid = "MySSID";
const char* password = "Pass";
// Create an instance of the server
// specify the port to listen on as an argument
WiFiServer server(80);
unsigned long timer = 0;
unsigned long firstMillis = 0;
delay(10);
pinMode(0, OUTPUT);
pinMode(2,INPUT);
pinMode(2, INPUT_PULLUP);
// Connect to WiFi network
Serial.println(ssid);
Serial.println("");
// Start the server
server.begin();
// Print the IP address
unsigned long currentMillis = millis();
if(currentMillis - firstMillis > (timer*60000)) {
digitalWrite(0, 0);
firstMillis = currentMillis;
if (!client) {
return;
// Wait until the client sends some data
Serial.println("new client");
while(!client.available()){
delay(1);
String command1 = client.readStringUntil('/');
String command = client.readStringUntil('/');
Serial.println(command);
if (command == "12") {
if(digitalRead(0))
digitalWrite(0, 0);
client.print(F("0,0"));
else
digitalWrite(0, 1);
client.print(F("0,1"));
