I used the code from sparkfun to make a thermostat AP web server. It works like a charm but it can t actualize the actual temp (and doing other stuff) itself. I post the code of the loop. See comment.
When I put some code before WiFiClient, the AP wifi not shows up o I can t connect to It.
I don t know if I m clear. Sorry for that.
Thank you very much in advance
Morgan
Void loop(){
//I need to do some stuff here like checking the actual temperature. Otherwise the thermostat will only work when a client is connected
If (!client) {
return;
