If every process goes fine, enter the correspondence callback , for example, connect succeed ,enter connected callback;
If anything goes wrong, it will enter the reconnect callback..
Explore... Chat... Share...
soccou wrote:I am not sure if I am doing something wrong or not.
I am getting vary random behavior with the TCP reconnect callback. I am trying to do a very simple HTTP POST to a webserver.
Most often on the ESP8266 the function defined for espconn_regist_reconcb fires with the message:
"Connection error: -11 - Not connected" and espconn_regist_recvcb function does not execute. I also don't see any return data.
but then again randomly sometimes it does with no changes in the code.
The odd part is I have control of the webserver and I can see that the POST was recieved on the remote end with no problems.
Is there some kind of TCP timeout delay that is firing the reconnect callback function or something else prematurely closing the TCP connection?
Any suggestions welcome.
Sokkou
