#include <ArduinoJson.h>
#include <DallasTemperature.h>
#include <OneWire.h>
#include <TextFinder.h>
#include <String.h>
//include this library for MAC address reassigning. (For Hotel WiFi)
extern "C" {
#include <user_interface.h>
//Use this to reassign mac address of the ESP8266 (Hotel WiFi)
bool wifi_set_macaddr(uint8 if_index, uint8 *macaddr);
// Data wire is plugged into pin 2
#define ONE_WIRE_BUS D1
//Pass oneWire intance to communicate with any oneWire devices
OneWire oneWire(ONE_WIRE_BUS);
//Pass oneWire reference to Dallas Temperature
DallasTemperature sensors(&oneWire);
WiFiClient client;
TextFinder finder( client );
const char* ssid = "ATT6VMY3cI";
const char* password = "6de7yde5umi3";
const char* host = "www.smallbatchbru.com"; // Your domain
bool debugging = true; //whether or not we want to print to the serial port
float f; //current fermentation temp
int setVal; //the value retrieved from setFromSQL.html and desired temp
int highDifference = 2;//desired high and low temp range
int lowDifference = 2;
unsigned long compDelay = 600000; //compressor delay in milliseconds
unsigned long lightLastOff = 0; // used in compressor delay timer
int outOfRange = 70; //Used for sending the email through IFTTT if the temp gets too high inside
int relayPin = D2; //the relay
bool executed = false; //keep track of the sendEmail function to only run once
digitalWrite(D1, HIGH);
pinMode(D1, OUTPUT);
pinMode(D4, OUTPUT);
pinMode(relayPin, OUTPUT);
// Start with the built-in LED off
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
delay(50);
// Start up the library for the sensor
sensors.begin();
delay(50);
//Reassign the MAC address to my iPhone address (for Hotel WiFi)
//uint8_t mac[6] {0x7c, 0x04, 0xd0, 0x17, 0x23, 0x6F};
//wifi_set_macaddr(STATION_IF, mac);
//WiFi.hostname("DicksESP");
WiFiConnect();
delay(100);
testConnection(); //If the WiFi was interrupted, re-connect to the AP
delay(2000);
callTemperatures(); //Call the temperatures from the DS18b20 sensor
delay(2000);
getSetTemp(); //GET request that retrieves the temperature from the SQL database
delay(2000);
compressorControl(); //Determine whether or not to turn the fridge on or off. There is a 10 minute compressor delay built in
delay(1000);
postTemp(); //POST the temperature from the sensor to a PHP file and then to the site
delay(2000);
sendEmail(); //Send an email through IFTTT if the fridge is out of the set range.
delay(2000);
void WiFiConnect() {
if (debugging) {
Serial.println(ssid);
// Connect to the WiFi access point
WiFi.begin(ssid, password);
/*While the WiFi is not connected, print some periods in half
* second intervals and turn off the light
if (debugging) {
if (debugging) {
Serial.println("IP address: " + WiFi.localIP());
/*Turn on the light once the WiFi is connected*/
digitalWrite(LED_BUILTIN, LOW);
void testConnection() {
// If the WiFi isn't connected, re-connect the WiFi
if (WiFi.status() != WL_CONNECTED) {
WiFiConnect();
void callTemperatures() {
if (debugging) {
Serial.println("Requesting temperartures...");
sensors.requestTemperatures();
if (debugging) {
Serial.println("DONE");
Serial.print("Temperature for the device 1 (index 0) is: ");
Serial.println(sensors.getTempFByIndex(0));
f = sensors.getTempFByIndex(0);
void compressorControl() {
/* If the temperature from the probe is less than or equal
* to the set value, then turn the compressor off
if (f <= setVal - lowDifference) {
digitalWrite(relayPin, LOW);
digitalWrite(D4, LOW);
/* Not really necessary, but I assigned the
current time to millis to help visually keep track of current millis */
unsigned long currentMillis = millis();
/* If the temperature from the probe is greater than the set value AND it has been more than 10 minutes
* since the compressor last shut off; then turn the compressor back on
if ((f > setVal + highDifference) && (currentMillis - lightLastOff) >= compDelay) {
lightLastOff = millis();
digitalWrite(relayPin, HIGH);
digitalWrite(D4, HIGH);
if (debugging) {
Serial.print("Setting in compressor control: ");
Serial.println(setVal);
void postTemp() {
String temp = "f=";
String currentData = temp+f;
if (client.connect("www.smallbatchbru.com", 80)) {
if (debugging) {
Serial.println("Connected to POST");
client.println("POST /controller/fermTempPHP.php HTTP/1.1");
client.println("Host: www.smallbatchbru.com");
client.println("Connection: close");
client.println("Content-Type: application/x-www-form-urlencoded");
client.print("Content-Length: ");
client.println(currentData.length());
client.println();
client.print(currentData);
} else {
if (debugging) {
Serial.println("POST connection failed");
if (!client.connected()) {
if (debugging) {
Serial.println("disconnecting.");
client.flush();
client.stop();
void getSetTemp() {
if (debugging) {
Serial.println("Connected...getting SQL value");
client.println("GET /controller/setFromSQL.html HTTP/1.1");
client.println();
} else {
if (debugging) {
Serial.println("Connection to get SQL value failed");
if (client.connected()) {
finder.find("<p>");
setVal = finder.getValue();
if (debugging) {
Serial.print("The temperature setting from the database is: ");
} else {
if (debugging) {
Serial.println("Client not available");
if (debugging) {
Serial.println("disconnecting");
client.flush();
client.stop();
while (true);
void sendEmail() {
if (f > outOfRange && executed == false) {
if (client.connect("maker.ifttt.com", 80)) {
if (debugging) {
Serial.println("Connected to Maker Webhooks");
client.println("POST /trigger/out_of_range/with/key/mv8BNkmZZIGrhCF9aUFtaBFJ_xys-L0d3pF1VCQ7rFa HTTP/1.1");
client.println("Host: maker.ifttt.com");
client.println();
} else {
if (debugging) {
Serial.println("Could not connect to Maker WebHooks");
if (debugging) {
client.flush();
client.stop();
while (true);
executed = true;
philbowles wrote:CAVEAT: i haven't looked at your code, but a few general pointers might help:
a) timer overflow. Try to get a handle on EXACTLY how many seconds "a few days" is...does the number look strangely familiar?
b) possible slow memory leak. sprinkle some print functions showing the value of ESP.getFreeHeap() at strategic points...or in a (say) 30minute timer call. IS the value going steadily down? If you, u got leaks
c) most likely (and hardest to find, hardest to fix) heap fragmentation...you may well need to overhaul your code and/or do a strategic reboot at certain intervals (dirty, but works...)
hope this point you in the right direction
Thanks! I’ll add a reboot for now and start looking for leaks
