If I simply power the ESP up with 2 D cell battery or a level shifting adapter board with 3.3V regulator, the module powers up and connects to my AP very quickly. If I connect the TX pin to a level shifting circuit or directly to the TTL PIC RX, the ESP almost never connects to my AP and falls-back to its internal AP mode.
Pins 5-reset, 4 PIO-2, 6 PIO-0, are floating on my adapter board. On some sites I see pins 7,5,3,2, tied high. Pin 6 & 4 high with a 10K pull up resister. Is there any general rule of thumb what to do with unused pins?
Also in my case pin 3 CH_PD is tied high directly to VCC. I see some application use a pull-up resister some do not. Is there a general rule of thumb for the enable input?
