- Tue Jan 13, 2015 12:10 am
#7165
Code: Select all0x00000000 **** Exc Protected area
0x20000000 **** --- Unmapped, repeated pattern
0x3FF00000 0x010000 R/W Memory-mapped I/O, repeated every 0x100.
0x3FF10000 0x010000 R only Mapped, zeroes
0x3FF20000 0x001800 R/W I/O registers
0x3FF21800 0x09E800 R only Mapped, zeroes
0x3FFC0000 0x020000 --- Unmapped, repeated pattern
0x3FFE0000 0x008000 R only Mapped, zeroes
0x3FFE8000 0x014000 R/W User data RAM. Available to applications.
0x3FFFC000 0x004000 R/W ETS system data RAM.
0x40000000 0x010000 R only Internal ROM.
0x40010000 0x010000 R only Internal ROM (repeated 0x40000000).
0x40020000 0x0E0000 R only Mapped, zeroes
0x40100000 0x008000 R/W RAM
0x40108000 0x038000 R only Mapped, zeroes
0x40140000 0x0C0000 --- Unmapped, repeated pattern
0x40200000 0x100000 R only SPI Flash is mapped (512k->2x repeated, 16Mb - 1Mb mapped )
0x40300000 **** --- Unmapped, repeated pattern
0x60000000 0x001000 R/W I/O registers
0x60001000 0x000400 R/W RAM
0x60001400 0x000400 R/W I/O registers
0x60001800 0x000400 R/W RAM (repead 0x60001000)
0x60001C00 0x000400 R/W I/O registers (repead 0x60001400)
0x3FFFC704 = 0x000000A0 - Set CLK CPU ( ets_get_cpu_frequency() { return 0x3FFFC704}, ets_update_cpu_frequency(x) {0x3FFFC704 = x})
0x3FFFC708 = wdt_mode ( ets_wdt_get_mode(), ets_wdt_enable(), ets_wdt_disable(), ets_wdt_init())
0x600011FC = 0x00000005 - ESP SDK store number of simulatenously active TCP connections (espconn_tcp_set_max_con())
0x40100000 0x008000 R/W RAM = Start code SPI flash - 0x10 (00000_eagle.app.v6.bin)
