I am currently able to program 2 Esp01s that I have been using for several months, however I am unable to program the new Esp01s with the same programming hardware.
I have tried almost every setting combination in the IDE under Generic ESP8266 Module , but the error is always:
error: espcomm_upload_mem failed
this is the output from the debug window:
WARNING: Category 'Sensor' in library Adafruit_VL53L0X is not valid. Setting to 'Uncategorized'
Build options changed, rebuilding all
Archiving built core (caching) in: C:\Users\PERIGA~1\AppData\Local\Temp\arduino_cache_569886\core\core_esp8266_esp8266_generic_CpuFrequency_80,FlashFreq_40,FlashMode_qio,UploadSpeed_115200,FlashSize_1M64,ResetMethod_ck,Debug_Disabled,DebugLevel_None_____82358c2f9e86d376ed80024bea7f0df4.a
Sketch uses 248159 bytes (25%) of program storage space. Maximum is 958448 bytes.
Global variables use 33468 bytes (40%) of dynamic memory, leaving 48452 bytes for local variables. Maximum is 81920 bytes.
C:\Users\Perigalacticon\AppData\Local\Arduino15\packages\esp8266\tools\esptool\0.4.9/esptool.exe -vv -cd ck -cb 115200 -cp COM4 -ca 0x00000 -cf C:\Users\PERIGA~1\AppData\Local\Temp\arduino_build_98219/christmas_outdoor_display_ESP-01_1.ino.bin
esptool v0.4.9 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
setting board to ck
setting baudrate from 115200 to 115200
setting port from COM1 to COM4
setting address from 0x00000000 to 0x00000000
espcomm_upload_file
espcomm_upload_mem
setting serial port timeouts to 1000 ms
opening bootloader
resetting board
trying to connect
flush start
setting serial port timeouts to 1 ms
flush complete
espcomm_send_command: sending command header
espcomm_send_command: sending command payload
espcomm_send_command: receiving 2013 bytes of data
read 0, requested 1
error: failed reading byte
warning: espcomm_send_command: cant receive slip payload data
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
resetting board
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
trying to connect
flush start
flush complete
read 0, requested 1
warning: espcomm_sync failed
error: espcomm_open failed
If I view the serial monitor output on startup at 74880 Baud I see:
load 0x40100000, len 2408, room 16
tail 8
chksum 0xe5
load 0x3ffe8000, len 776, room 0
tail 8
chksum 0x84
load 0x3ffe8310, len 632, room 0
tail 8
chksum 0xd8
csum 0xd8
2nd boot version : 1.6
SPI Speed : 40MHz
SPI Mode : QIO
SPI Flash Size & Map: 8Mbit(512KB+512KB)
jump to run user1 @ 1000
rf cal sector: 249
rf[112] : 00
rf[113] : 00
rf[114] : 01
SDK ver: 2.0.0(5a875ba) compiled @ Aug 9 2016 15:12:27
phy ver: 1055, pp ver: 10.2
"⸮j⸮⸮
I would expect the following settings to work:
QIO flash mode
1M / 64k
ck reset
40MHz flash speed
80MHz cpu speed
115200 upload speed
But they have not and I have tried many combinations and variations. When the module is powered on the blue led flashes ~5-10 times randomly within 5 seconds then stops. When attempting to upload the blue led flashes a few times then stops.
The exact same programming setup works with other ESP01 modules I use so I am confused why it's not working for these new ones. This is the link to the product page:
https://www.ebay.com/itm/ESP-01S-ESP8266-ESP-01-Wireless-Transceiver-Module-Breakout-Breadboard-Adapter/112221319911?ssPageName=STRK%3AMEBIDX%3AIT&var=412532827457&_trksid=p2057872.m2749.l2649
Any ideas?
