I've been staring at the C sources trying to figure out how the PCM firmware module sets up the Sigma Delta hardware but just can't see it. If a new PCM object is created with the pcm.SD argument, it seems to check for the sigma_delta module:
if (driver == PCM_DRIVER_SD) {
cfg->pin = luaL_checkinteger( L, 2 );
MOD_CHECK_ID(sigma_delta, cfg->pin);
but I'm left with many questions - some simple such as what dependencies there are when using the two firmware modules. I can build the firmware without the Sigma Delta module yet the PCM module works OK. I hope someone is able to clarify and possibly give some tips on how it might be possible to change the base frequency of the PCM
