By btidey
#73307 Can you point out where it recommends to ground GPIO0?
That would normally be a bad idea as that pin is sensed during boot and if it is 0 puts it in flash mode.
By hortplus
#73316
btidey wrote:Can you point out where it recommends to ground GPIO0?
http://www.instructables.com/id/How-to- ... n-ESP8266/
That was the whole idea to flash new repeater firmware from:
https://github.com/martin-ger/esp_wifi_repeater
By rudy
#73321 Grounding GPIO-0 is only done to get the ESP8266 into the flash programming mode. To run the application code that input must be high during the reset of the chip.
Maybe I just don't understand what you mean by instability. I have only found the ESP8266 to be unstable when it was not supplied proper power.
By hortplus
#73322 Can you describe the flashing process for me? I was under the impression gpio0 was held low during the entire process but you seem to be suggesting otherwise.
