rudy wrote:The first thing I would do is to put a diode in series with the power supply. This should go a long way in protecting your circuit when someone connects the power backwards.
If I were to continue using the voltage regulator rather than a buck converter, (I would like to use a buck converter or switch mode power supply but fear the design of such is above my ability), then would inserting a schottky diode in series as you suggested and then inserting a Transil to ground like the following be ok do you think?
rudy wrote:I designed a speed controller for electric motor on a salt and sand spreaders just over a year ago. One 3/4 hp motor on the conveyor and 1/3 hp on the spinner. It is for 12 volt battery systems and that meant the currents were pretty high. At the rated load the motor currents were 55 Amps and 27 Amps. Overload was higher than that. We used a variable current limit that allowed for short term overloads and motor start up. Protection of the CPU core wasn't too hard but the power section was a little more difficult (costly).
One of the reasons I am using a stepper motor in this project is because we tried a dc motor but gave up trying to get a wide enough operating rev range and still have enough torque to drive the equipment. I used an "off the shelf" 43a H-bridge driver for our testing.
Many thanks Rudy.
