Luiz Almeida wrote:I was googling about that same issue and got here.
Could you be more specific. What is the same issue? The last post from the OP was that he suspected a problem on his PCB.
Does someone have this working properly?
Based on the second post in this thread I would say yes.
I have also used those charger boards to supply ESP modules from 18650 batteries. I have also used that board in a commercial design for a Raspberry Pi with minor modifications, removed the USB connector, lift and connect to the enable pin of the charger chip.
