https://www.youtube.com/watch?v=fxP9hnZysgo
Explore... Chat... Share...
samehhady wrote:It should be fairly easy to implement on ESP, just scan and search for a specific string in the AP name, if available then parse the name and save it then connect.
samehhady wrote:Also for bit securing your password, you can put them in reverse and organize them through code, or maybe do some find and replace techniques.
