By LZYDavid
#75407 Hi guys, total newbie here, had build a oxygen gas sensor device using adafruit pro trinket which can read off from a connected oxygen sensor and be able to warn user if the oxygen level is above or below the safe level by blinking led.
I have also brought the huzzah esp8266 from adafruit, i want to incorporate the esp8266 onto device.
is it possible to use the esp8266 to display the readings on any nearby pc through wifi.
For example, a nearby pc is able to acquire the oxygen level of a room with the device in it through wifi.
Any help or guidance would be greatly appreciated!
Thanks
