In the end you will need some sort of sync-method.
Explore... Chat... Share...
FranckM wrote:I succeeded by using UDP, but the lag is considerable and my stations end up de-synced by half a second of what the AP is showing.
rudy wrote:FranckM wrote:I succeeded by using UDP, but the lag is considerable and my stations end up de-synced by half a second of what the AP is showing.
I'm surprised by that. UDP should be quick. I wonder if it is an implementation issue rather than UDP.
