I have been working on solar powered ESP8266 project.
So far, i have estabilished to run ESP8266 with 6V solar panel and 3.7 V lipo battery.
I am ensure that, ESP8266 runs approximately 20 hours and i collected data.
But my problem is that, when the Battery drops to under 3v, esp8266 is powered off ( of course. )
After that, the battery is charged and rised until 3.8 volt and i am sure that ams1117 outputs 3.333 volts to power on ESP8266 again. However, i have to press the reset button to run the ESP8266, it does not boot up without manuel reset.
I couldn't understand the problem. As charger board i use TP4056 protected.
Do you have any suggestions ?
