By Cosmic Mac
#75916 Hi guys,
I'm unable to use HTTP client from inside a ESPAsyncWebServer callback ("connection refused" error).
Same function called from anywhere outside the callback works as expected.
My test code:
Code: Select all#include <Arduino.h>
#include <ESP8266HTTPClient.h>
#include <ESP8266mDNS.h>
#include <ESPAsyncWebServer.h>
const char *ssid = "********";
const char *password = "********";
const char *hostname = "esptest";
const char *url = "http://httpbin.org/ip";
HTTPClient http;
AsyncWebServer server(80);
void cltTest(const char *context) {
    Serial.printf("\n\n>>>> cltTest called from %s\nHeap: %d\n", context, ESP.getFreeHeap());
    http.begin(url);
    if (http.GET() > 0) {
        http.writeToStream(&Serial);
    http.end();
  Serial.setDebugOutput(true);
  Serial.printf("Attempting to connect to SSID: %s", ssid);
  WiFi.mode(WIFI_STA);
  WiFi.begin(ssid, password);
    delay(1000);
  Serial.println("\nConnected!");
  MDNS.begin(hostname);
  MDNS.addService("http", "tcp", 80);
  server.on("/", HTTP_GET, [](AsyncWebServerRequest *request) {
    cltTest("Server callback");
    request->send(200, "text/plain", "Done");
  server.begin();
  cltTest("Setup");
  MDNS.update();
And some traces, after pointing my browser at http://esptest.local :
Code: Select allSDK:2.2.1(cfd48f3)/Core:2.4.1/lwIP:1.4.0rc2
>>>> cltTest called from Setup
Heap: 38776
[HTTP-Client][begin] url: http://httpbin.org/ip
[HTTP-Client][begin] host: httpbin.org port: 80 url: /ip
[HTTP-Client] connected to httpbin.org:80
[HTTP-Client] sending request header
GET /ip HTTP/1.1
Host: httpbin.org
User-Agent: ESP8266HTTPClient
Connection: close
Accept-Encoding: identity;q=1,chunked;q=0.1,*;q=0
[HTTP-Client][handleHeaderResponse] RX: 'HTTP/1.1 200 OK'
[HTTP-Client][handleHeaderResponse] RX: 'Connection: close'
[HTTP-Client][handleHeaderResponse] RX: 'Server: gunicorn/19.8.1'
[HTTP-Client][handleHeaderResponse] RX: 'Date: Sun, 13 May 2018 15:26:56 GMT'
[HTTP-Client][handleHeaderResponse] RX: 'Content-Type: application/json'
[HTTP-Client][handleHeaderResponse] RX: 'Content-Length: 26'
[HTTP-Client][handleHeaderResponse] RX: 'Access-Control-Allow-Origin: *'
[HTTP-Client][handleHeaderResponse] RX: 'Access-Control-Allow-Credentials: true'
[HTTP-Client][handleHeaderResponse] RX: 'Via: 1.1 vegur'
[HTTP-Client][handleHeaderResponse] RX: ''
[HTTP-Client][handleHeaderResponse] code: 200
[HTTP-Client][handleHeaderResponse] size: 26
{"origin":"123.45.67.89"}
[HTTP-Client][writeToStreamDataBlock] connection closed or file end (written: 26).
[HTTP-Client][end] tcp stop
[HTTP-Client][end] tcp is closed
pm open,type:2 0
>>>> cltTest called from Server callback
Heap: 35448
[HTTP-Client] failed connect to httpbin.org:80
[HTTP-Client][returnError] error(-1): connection refused
Any idea?
Cheers
By rudy
#76000
Cosmic Mac wrote:Well, I just tried with ESP32, and this code is running flawlessly... (after usual tweaks on dependencies names)
When I read this I assumed you meant that you found your solution. Maybe that's what other people thought.
Now, knowing you still are looking for a solution, unfortunately I don't know enough to help.
