I have a simple server that sends an AJAX request when a button is clicked.
Everything works but I am getting multiple requests:
String header = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n";
String html_1 = R"=====(
<!DOCTYPE html>
<html>
<head>
<meta name='viewport' content='width=device-width, initial-scale=1.0'/>
<meta charset='utf-8'>
<style>
body {font-size:140%;}
#main {display: table; margin: auto; padding: 0 10px 0 10px; }
h2 {text-align:center; }
#LED_button { padding:10px 10px 10px 10px; width:100%; background-color: #4CAF50; font-size: 120%;}
</style>
<script>
function switchLED()
var button_text = document.getElementById("LED_button").value;
if (button_text=="Turn on the LED")
document.getElementById("LED_button").value = "Turn off the LED";
ajaxLoad('LEDON');
else
document.getElementById("LED_button").value = "Turn on the LED";
ajaxLoad('LEDOFF');
var ajaxRequest = null;
if (window.XMLHttpRequest) { ajaxRequest =new XMLHttpRequest(); }
else { ajaxRequest =new ActiveXObject("Microsoft.XMLHTTP"); }
function ajaxLoad(ajaxURL)
if(!ajaxRequest){ alert("AJAX is not supported."); return; }
ajaxRequest.open("GET",ajaxURL,true);
ajaxRequest.onreadystatechange = function()
if(ajaxRequest.readyState == 4 && ajaxRequest.status==200)
var ajaxResult = ajaxRequest.responseText;
ajaxRequest.send();
</script>
<title>LED Control</title>
</head>
<body>
<div id='main'>
<h2>LED Control</h2>
<input type="button" id = "LED_button" onclick="switchLED()" value="Turn on the LED" />
</div>
</body>
</html>
#include <ESP8266WebServer.h>
#include <WiFiManager.h>
#include <ESP8266mDNS.h>
WiFiServer server(80);
String request = "";
int LED_Pin = D1;
void setup()
pinMode(LED_Pin, OUTPUT);
Serial.println(F("Serial started at 115200"));
WiFiManager wifiManager;
WiFi.setAutoReconnect(true);
wifiManager.autoConnect("ESP8266","password");
// if you get here you have connected to the WiFi
Serial.println("Connected.");
if (!MDNS.begin("esp8266")) { Serial.println("Error setting up MDNS responder!"); }
else { Serial.println("mDNS responder started"); }
// start a server
server.begin();
} // void setup()
void loop()
if (client)
request = client.readStringUntil('\r');
Serial.print("request: "); Serial.println(request);
// If we have a control code we just need to switch the LED. Do not need to resend the HTML
if ( request.indexOf("LEDON") > 0 ) { digitalWrite(LED_Pin, HIGH); }
else if ( request.indexOf("LEDOFF") > 0 ) { digitalWrite(LED_Pin, LOW); }
// No control code (or unknown code) so send the HTML
else
client.flush();
client.print( header );
client.print( html_1 );
delay(5);
// The client will actually be disconnected when the function returns and the client object is detroyed
} // void loop()
Serial monitor:
request: GET / HTTP/1.1
request: GET /LEDON HTTP/1.1
request: GET /LEDOFF HTTP/1.1
Each button click results in up to 10 requests being printed.
