By cluberic
#77909 I just bought a TTGO T-Beam. It has an ESP32, 433/868/915 mhz Lora, WiFi, and Bluetooth. The GitHub for this board is useless. I can't find any documentation of this online. I don't even know what board to choose in the Arduino IDE to upload code to. Can anyone help?
I want to use this board as a GPS tracker using the LoRa radio. All this needs to do is transmit GPS coordinates over 915mhz.
By rudy
#77915 Whatboard have you tried? What code have you tried. Where did you you buy it? Have you contacted the Lily GO online store? https://www.aliexpress.com/store/2090076#
It is ironic that you complain about lack of information about the board, then ask for help but provide almost no information.
EDIT:
I found the following, see if they help. You need to try harder finding information. Or do some research before you buy things.
http://ttgobbs.com/viewthread.php?tid=17131
Read through this. https://www.thethingsnetwork.org/forum/ ... rt-2/11973
