By tipo1000
#78548 Hello,
I'm asking about these 3 GPIO's because they are used in bootstrapping.
Is there any limitations in using these pins for general input/output after startup condition has been passed?
For example: If I want to drive buzzer, drive LED or read button with these GPIO's.
Thanks,
Tipo
By QuickFix
#78595 With the information found in our Wiki, you should be able to find any limitations with the GPIO-pins of the ESP8266. :idea:
In short: don't assume that GPIO0, GPIO2 and GPIO15 are just like the other GPIO's.
As input, make sure they're properly pulled up or down and as output make sure anything connected (like a buzzer) influences the port at boot (at which time they act as input).
