Serial.printf("Time: %2d:%.2d:%.2d", 10, 11, 5);
outputs:
Time: 10:%.2d:%.2d
instead of:
Time: 10:11:05
apologies if this has been covered B4 !
Explore... Chat... Share...
Serial.printf("Time: %2d:%2d:%2d", 10, 11, 5);
QuickFix wrote:An integer value can't contain a precision specifier (the "." dot), try this instead:Code: Select allSerial.printf("Time: %2d:%2d:%2d", 10, 11, 5);
.precision
.number
For integer specifiers (d, i, o, u, x, X): precision specifies the minimum number of digits to be written. If the value to be written is shorter than this number, the result is padded with leading zeros.
