By TESTODYN
#79555 Hi All
on IoT device, ESP8266 Arduino, I've have some issue with random disconnections
User can set SSID and PASSWORD with an APP, so the code hase been a little modified starting from standard samples
cutting here below some snippets of my code
void setup()
   WiFi.setAutoConnect(false)
   WiFi.setAutoReconnect(true);
   WiFi.hostname(("MYDEVICE_" + serialNumber).c_str());
   if (AP)
      turnAP(true);
   else if (WIFI)
      WiFi.mode(WIFI_STA);
      connectToWiFi(&ssid[0], &pass[0]);
   else
      WiFi.mode(WIFI_OFF);
   loopCounter = 0;
} // setup
void loop()
   if (WiFi.status() == WL_CONNECTED)
      if (lastConnectionState != WL_CONNECTED)
         initWebSocket();
         connectWebSocket();
      else
         webSocket.loop();
   //Connection error during NORMAL BEHAVIOUR
   else if ((WiFi.status() == WL_NO_SSID_AVAIL ||
          WiFi.status() == WL_CONNECT_FAILED ||
          WiFi.status() == WL_CONNECTION_LOST) && !accessPointIsOn)
      handleNetworkError(false);
   //Connection error during AP
          WiFi.status() == WL_CONNECTION_LOST) && accessPointIsOn)
      lastConnectionError = WiFiStatusToString();
      WiFi.disconnect();
      delay(50);
   lastConnectionState = WiFi.status();
   loopCounter++;
Everithing works fine but sometimes, randomly, maybe after one hour or one week, I find the ESP not connected
I know... I used WiFi.setAutoConnect(false)
The reason is that I noticed that wiithout it, changing SSID after setup seems to be difficult
Without that, ESP starts immediately with automatic connection and this does not allow me to change SSID/PWD
setAutoReconnect works fine. In Fact, i I restart the router, ESP reconnect automatically
The proble is, don't know why, but sometimes I find ESP not connected
WHat I missing?
Is anybody can help me please :) ?
Thanks
By btidey
#79561 See description of setAutoConnect and setAutoReconnect
https://github.com/esp8266/Arduino/blob ... -class.rst
In particular,
"If parameter autoReconnect is set to true, then module will try to reestablish lost connection to the AP. If set to false then module will stay disconnected."
If you want to change SSID / passwords then check out WifiManager for a user friendly solution to this.
I also usually put an occasional check o Wifi status in my application loop to trigger a reconnect if required.
By TESTODYN
#79568 ok thanks
in my case, autoreccenct is true... autoconnect is false
Qheat are you used to do for example? do you set autoconnect to false?
btidey wrote:I also usually put an occasional check o Wifi status in my application loop to trigger a reconnect if required.
would you be so kind to share a sample of what you mean?
