Second Question is when in sleep mode is there a possible way to wake the ESP8266 out of sleep with a button?
I'm not using the wifi on the ESP8266 so not sure how i can disable the ESPwifi? Sorry that was three questions.
Joseph
Explore... Chat... Share...
The Power is still in the milli amp range Not as high as before but still not low as it should be.
