By Emiliano del Campo
#80346 Sometimes the webserver get stuck with a new client and doesn't disconnect it.
#include <Servo.h>
Servo servo1;
int pinservo = D2;
int pulsomin = 1000;
int pulsomax = 2000;
const char* ssid = "Manuela";
const char* password = "manuel34068833";
int ledPin = D4;
WiFiServer server(80);
  delay(10);
  servo1.attach(pinservo,pulsomin,pulsomax);
  servo1.write(50);
  pinMode(ledPin, OUTPUT);
  digitalWrite(ledPin, LOW);
  // Connect to WiFi network
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  Serial.println("");
  // Start the server
  server.begin();
  // Print the IP address
  Serial.print("Use this URL : ");
  Serial.print("http://");
  Serial.print(WiFi.localIP());
  Serial.println("/");
  if (!client) {
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available()){
    delay(100);
  String request = client.readStringUntil('\r');
  Serial.println(request);
  client.flush();
  // Match the request
  int value = LOW;
  if (request.indexOf("Abrir") != -1) {
    digitalWrite(ledPin, HIGH);
    value = HIGH;
    servo1.write(39);
    delay(400);
    servo1.write(50);
  if (request.indexOf("AbrirYcerrar") != -1){
    value = LOW;
    servo1.write(39);
    delay(400);
    servo1.write(50);
    delay(55000);
    servo1.write(39);
    delay(400);
    servo1.write(50);
  // Return the response
  client.println("HTTP/1.1 200 OK");
  client.println("Content-Type: text/html");
  client.println(""); //  do not forget this one
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.println("<style> a {font-size: 104px;background-color: #4dd2ff;color:white;}</style>");
  client.println("<br><br>");
  client.println("<h1>Clickea <a href=\"/Abrir\">ACA</a> Para abrir el porton</h1>");
  client.println("</html>");
  delay(100);
  Serial.println("Client disconnected");
  Serial.println("");
The monitor output..
Code: Select all 12:53:13.258 -> Connecting to Manuel
12:53:13.750 -> ....
12:53:15.256 -> WiFi connected
12:53:15.256 -> Server started
12:53:15.256 -> Use this URL : http://192.168.1.48/
12:53:17.853 -> new client
12:53:17.923 -> GET / HTTP/1.1
12:53:18.031 -> Client disconnected
12:53:18.031 ->
12:53:18.031 -> new client
12:53:18.357 -> GET /favicon.ico HTTP/1.1
12:53:18.445 -> Client disconnected
12:53:18.445 ->
12:53:18.935 -> new client  //stucked here
