Different grades of PTFE wire rated at 160/260C
Perhaps run bare wire through some PTFE tube which would be rated the same as the insulation? Perhaps a bit higher if there is an air gap between the wire and insulation.
Also silicone wire about 200C
Interestingly the glass fibre wire I have seen is only rated to about 200C as well
Of course it all depends the type/brand of wire you buy.
