By ESPCrypt
#80785 Hello,
I would like to enquire about the syntax in regards to a POST request and sending a variable within that request.
The below for example will successfully POST a request of 2 specific values.
int httpcode = http.POST("uservalue=112233&user=7");
However what I would like to achieve is sending a String/Variable as one of the values. Something like this -
int httpcode = http.POST("uservalue=(VARIABLEHERE)&user=7");
Is this possible?
Thank you.
By Bonzo
#80814 If you build up the string outside the post it will work but I have not tried it the way you want.
Out of interest have you actually tried it?
Code: Select allString data = "uservalue=" + VARIABLEHERE + "&user=7";
int httpcode = http.POST(data);
I think this correct except there might be a problem with variable types.
By martinayotte
#80815
It should be the following instead :
Code: Select allString data = String("uservalue=") + VARIABLEHERE + "&user=7";
