schufti wrote:if you are using latest esp arduino core, switch back to 2.4.2
the same thing is happening with this version
Explore... Chat... Share...
ets Jan 8 2013,rst cause:0, boot mode:(3,6)
unknown reset
ets_main.c ⸮
int LED = 5;
uint32_t TIEMPO_DeepSleep = 4e6;
pinMode(LED, OUTPUT);
digitalWrite(LED, HIGH);
// TIEMPO_Referencia = millis();
if (millis() > 3000){
ESP.deepSleep(TIEMPO_DeepSleep, WAKE_RF_DISABLED);
tail 8
chksum 0x2d
csum 0x2d
vbb28d4a3
~ld
