By btidey
#81099 This is the type of structure I commonly use.
Code: Select all#define STATE_0 0
#define STATE_1 1
#define STATE_2 2
int state = STATE_0;
int counter;
void stateMachine() {
   switch(state) {
      case STATE_0 :
         //check whether a state transition should be made
         if(counter > 20) {
            //set state to transition to
            state = STATE_1;
            //do actions on changing state
            Serial.println("Switching to state 1");
            counter = 0;
         break;
      case STATE_1 :
         if(counter > 30) {
            state = STATE_2;
            Serial.println("Switching to state 2");
            counter = 0;
         break;
      case STATE_2 :
         if(counter > 40) {
            state = STATE_0;
            Serial.println("Switching to state 0");
            counter = 0;
         break;
setup {
loop {
   stateMachine();
   // do other stuff
   counter++;
   delay(100);
Note that several different state machines can be called from the main loop to manage different activities. The counter in the example is just a trivial method to show transitions. Normally one might be testing for other conditions. State transitions can also be triggered by other activities. E.g. a button press or a web server call may change state and trigger a sequence of activities through further state transitions.
By RichardS
#81102 You can also use yield(); exactly the same as delay(0);
In theory it delays zero milliseconds, as opposed to the user who said use delay(1) which will delay a fill millisecond...
Its just not as obvious to use delay(0) as it seems wrong.
RichardS
By eben80
#86279 Hi everyone,
I'm having an issue with this too and yield or delay does not seem to help as it still bootloops.
Loop code:
Code: Select allvoid loop()
  count = (count + 1) % 10; // keep count between 0 to 9
  my_tube1.crossfade_init(count, 15, 127, 0);
  my_tube2.crossfade_init(10-count, 15, 127, 0);
  // my_tube3.crossfade_init(count, 15, 127, 0);
  // my_tube4.crossfade_init(10-count, 15, 127, 0);
      again, crossfade_run() is non-blocking, that means
    you can run other tasks in the loop.
      just make sure to call it at least every 33ms
    and check its return value to see if it's finished.
  while(1)
    yield();
    unsigned char result1 = my_tube1.crossfade_run();
    unsigned char result2 = my_tube2.crossfade_run();
    // unsigned char result3 = my_tube2.crossfade_run();
    // unsigned char result4 = my_tube2.crossfade_run();
    // exit when both animations are finished
    if(result1 == EXIXE_ANIMATION_FINISHED && result2 == EXIXE_ANIMATION_FINISHED)
      break;
  my_tube1.set_led(127, 40, 0); // orange;
  my_tube2.set_led(127, 0, 127); // purple;
  my_tube3.set_led(127, 40, 0); // orange;
  my_tube4.set_led(127, 0, 127); // purple;
Offending exixe library code https://github.com/dekuNukem/exixe:
Code: Select allunsigned char exixe::crossfade_run()
  unsigned long current_frame = (millis() / EXIXE_ANIMATION_FRAME_DURATION_MS) - animation_start_frame;
 Serial.println(current_frame);
  if(current_frame > animation_duration)
    animation_src_digit = animation_dest_digit;
    return EXIXE_ANIMATION_FINISHED;
  memset(spi_buf, 0, EXIXE_SPI_BUF_SIZE);
  memset(spi_buf, 0x80, EXIXE_SPI_BUF_SIZE - 5);
  spi_buf[0] = animation_overdrive ? EXIXE_SPI_HEADER_OD : EXIXE_SPI_HEADER;
  unsigned char temp = cap_float(animation_step * (float)current_frame);
  spi_buf[animation_src_digit] = 0x80 | (animation_brightness - temp);
  spi_buf[animation_dest_digit] = 0x80 | temp;
  spi_write();
  return EXIXE_ANIMATION_IN_PROGRESS;
