New to this. My project involves communicating digital data to a ESP8266 NodeMCU and writing that data to Think Speak channel. I think my problem may be trying to use a mobile hotspot for internet access. I have pasted code below
Best Regards
#include <Arduino.h>
#include <EEPROM.h>
#define USE_SERIAL Serial
#include <ESP8266HTTPClient.h>
// Variable init
const int buttonPin = D2; // variable for D2 pin
int contagem = 0; // variable to store the “rise ups” from the flowmeter pulses
int litros = 0;
char thingspeak_string[200]; //string used to send info to the server ThingSpeak
char litros_string[10]="0";
int addr = 0; //endereço eeprom
//SSID and PASSWORD for the AP (swap the XXXXX for real ssid and password )
const char* ssid = "iphone";
const char* password = "tj6kp68pr8mux";
//HTTP client init
HTTPClient http;
//Webserver init
WiFiServer server(80);
//Interrupt function, so that the counting of pulse “rise ups” dont interfere with the rest of the code (attachInterrupt)
void pin_ISR()
contagem++;
// Serial Comunication init
delay(10);
// EEPROM access init
EEPROM.begin(1);
litros=EEPROM.read(addr);
// Initialization of the variable “buttonPin” as INPUT (D2 pin)
pinMode(buttonPin, INPUT);
// Wifi connection init
Serial.print("A iniciar ligação...");
WiFi.begin(ssid, password);
//Waiting for the connection to be established
Serial.print("Waiting for the connection...");
delay(2000);
if(WiFi.status() == WL_CONNECTED)
Serial.printf("Connect to the SSID: %s",ssid);
// Starting Webserver
server.begin();
// Print the IP address
Serial.print("Use this URL to connect: ");
Serial.print("http://");
Serial.print(WiFi.localIP());
Serial.println("/");
Serial.print("A iniciar contagem dos litros...");
// Attach an interrupt to the ISR vector
attachInterrupt(digitalPinToInterrupt(buttonPin), pin_ISR, RISING);
Serial.print("Waiting for client....");
// Verify if a clients is connected to the server
// Reply from the local http server, and constrution of the page “on the fly”
client.println("HTTP/1.1 200 OK");
client.println("Content-Type: text/html");
client.println("Connection: keep-alive");
client.println(""); // do not forget this one
client.println("<!DOCTYPE HTML>");
client.println("<html>");
client.println("<head><meta http-equiv=\"refresh\" content=\"10\" >");
client.println("<script type='text/javascript'>");
client.println("function loadDoc() {");
client.println("var xhttp = new XMLHttpRequest();");
client.println("xhttp.onreadystatechange = function() {");
client.println("if (xhttp.readyState == 4 && xhttp.status == 200) {");
client.printf("document.getElementById('id_litros').innerHTML = %d",litros);
client.println("}");
client.println("};");
client.println("xhttp.open('GET', '', true);");
client.println("xhttp.send();");
client.println("</script></head>");
client.println("<body onload='setInterval(loadDoc, 5000);'>");
client.println("<br/><br/>");
client.printf("<div id='id_litros'>Estão contados %d litros!</div>",litros);
client.println("<iframe width=\"450\" height=\"260\" style=\"border: 1px solid #cccccc;\" src=\"https://thingspeak.com/channels/784526/charts/1?bgcolor=%23ffffff&color=%23d62020&dynamic=true&results=60&title=Contagem+de+Litros&type=line\"></iframe>");
client.println("</body>");
client.println("</html>");
client.stop();
delay(1);
// If the counting of transitions (Low to High, “rise ups”) it's higher than 330, count one litre more. Then do the rest of the functions (update to EEPROM variable, loca webserver and ThingSpeak)
//pulse per litre +/- 330 "www.hobbytronics.co.uk/yf-s201-water-flow-meter"
if(contagem > 330 )
litros++;
Serial.print("Litros: ");
Serial.print(litros);
//Write the new litres value to the EEPROM and put “contagem” variable to zero
EEPROM.write(addr, litros);
EEPROM.commit();
contagem = 0;
//The value of litres is sent to the ThingSpeak server. It is needed to have an account in ThingSpeak server before using this funcionality. You will have to copy the link given (something like this: https://api.thingspeak.com/update.json? ... field1=XXX), example below.
dtostrf(litros, 4, 2, litros_string);
sprintf(thingspeak_string,"https://api.thingspeak.com/update.json?api_key=LOEQ3EJ01OWYSH51&field1=%s", litros_string);
//String sent to ThingSpeak server.
http.begin(thingspeak_string);
//Send HTTP Header
int httpCode = http.GET();
// httpCode_code will be a negative number if there is an error
if(httpCode > 0) {
// file found at server
if(httpCode == HTTP_CODE_OK) {
String payload = http.getString();
Serial.print(" ");
Serial.println(payload);
} else {
Serial.printf("[HTTP] GET... failed, error: %s\n", http.errorToString(httpCode).c_str());
http.end();
}//stop counting
