By javadhabibi
#84011 Hi, I'm Using a ESP 12-e module in arduino IDE. I want to generate a clock and a data on my pins to communicate with a custom device. Something like this:
This is my related piece of code:
Code: Select allpinMode(CLK , OUTPUT);
  pinMode(DOUT , OUTPUT);
void Write_Bit_0(void){
    digitalWrite( DOUT , LOW );
    digitalWrite( CLK , HIGH );
    digitalWrite( CLK , LOW );
void Write_Bit_1(void){
    digitalWrite( DOUT , HIGH);
My problem is to increase CLK frequency. it seems that digitalWrite command take about 800 ESP clock to run!(I measured it with ESP.getCycleCount()).
Can anyone suggest a solution to increase CLK frequency up to 8 Mhz?
Thanks
By btidey
#84028 That looks like SPI with the right clock phase and polarity set up and data length set to 8.
By using the hardware SPI you can get very high clock frequencies; 8MHz no problem. Plus much lower software overhead as you are writing bytes rather than bit banging.
