By Yvonne de Vries
#84398 Hello,
I try to read if a radar switch sensor is high or low.
This is the code:
int mwsensor = 7;
pinMode(mwsensor, INPUT);
digitalRead(mwsensor);
Serial.println("hoi");
delay(1000);
I upload the code to the NodeMCU and this is returned in the serial monitor:
ets Jan 8 2013,rst cause:4, boot mode:(3,6)
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v8b899c12
~ld
I have no idea what's wrong. Normally I can upload code without any problem.
Can you please give me an advise.
Thank you.
Yvonne
