By MyESP
#84896 Hi all I have this sketch below which reads connected wifi users MAC addresses, I would like to save these MAC address into esp8266 EEPROM memory. How would I do that?
Code: Select all#include<user_interface.h>
  delay(5000);
  client_status();
  delay(4000);
void client_status() {
  unsigned char number_client;
  struct station_info *stat_info;
//  struct ip_addr *IPaddress;
  struct ip4_addr *IPaddress;
  IPAddress address;
  int i=1;
  number_client= wifi_softap_get_station_num();
  stat_info = wifi_softap_get_station_info();
  Serial.print(" Total Connected Clients are = ");
  Serial.println(number_client);
    while (stat_info != NULL) {
      IPaddress = &stat_info->ip;
      address = IPaddress->addr;
      Serial.print(stat_info->bssid[0],HEX);Serial.print(" ");
      Serial.print(stat_info->bssid[1],HEX);Serial.print(" ");
      Serial.print(stat_info->bssid[2],HEX);Serial.print(" ");
      Serial.print(stat_info->bssid[3],HEX);Serial.print(" ");
      Serial.print(stat_info->bssid[4],HEX);Serial.print(" ");
      Serial.print(stat_info->bssid[5],HEX);Serial.print(" ");
      stat_info = STAILQ_NEXT(stat_info, next);
      i++;
