TNX!!!
SDM Energy Meter: https://github.com/reaper7/SDM_Energy_Meter
MLEDScroll (TM1640 led matrix): https://github.com/reaper7/MLEDScroll
Explore... Chat... Share...
rudi wrote:Do i need to set the PIN_FUNCTION_SELECT too?
Do you know this too?
mamalala wrote:Toggling a pin, and using a timer to do so... Uses GPIO2 as output. 115200,n,8,1 and press 1, 2 or 3 to set different blinking speeds.
Greetings,
Chris
