ESP8266 air pressure and weather forecast sensor example
EasyIoT server now works on RaspberryPi and Windows.
Explore... Chat... Share...
hbouzas wrote:I have made a lot of modifications to the original code to setup the ESP8266 via web and not have to deal with serial, new code coming to http://www.horaciobozas.com
The new code handles power down gracefully and allows to properly identify the module when trying to connect to it for the first time.
